Vynuladikt
- May 4, 2016
- Northeast Iowa
- Love great audio, beermaking and pyrotechnics
and approaching 2K posts!!!We’re almost there! 100 pages!
yes sir....When you solder your wires in, get a bit better solder flow on your joints. Some of them look rather cold.
And ensure it still fits under the cap hold down plate...not a lot of room under there.
The plate actually has plenty of clearance over those caps in the photo of my S1.
Gene, when you fit it to the cradle and solder the remaining wires, turn up the heat some over 700 F., maybe 730-750. Those solid core wires are good heat sinks. A pointed tip isn't going to work well, use a screwdriver or chisel tip.
Add just a touch of flux to help wet the joint, then solder the wire. But before you pull the iron out, move up on the lug and blend in those cap leads. Get both sides of the lug, done!
Good prep work there!
I just ordered a roll of 22 AWG red to go along with the 22 AWG white that I had buried in another box. I'll redo the meter signal wires from the DCP with red and white per Joe's suggestion.yes sir...noted...
i will need some red 16ga...as i have none ..
i think i will get 3 feet of every color and guage that i dont have...i always have wire ...aircraft wire is similar...fire/smoke resistant....very tough wire...
comes in various colors as long as you get white....it is murder to trace...lol
Gene, look for PTFE or Teflon insulated, most of it is silver plated mil-spec.
Gene, I see you are using film caps to bypass the rectifier diodes. I used to do the same exact thing (same caps, too!).better???
In an attempt to share the wealth, I will offer a tip that was given to me by wattsabundant, who knows more than I do about this stuff -
For high energy AC circuits, the proper bypass capacitor is the ceramic X1 Type or the Y2 Type. These caps are considered "Safety Capacitors" because they are far more heat resistant than film caps which are more suited to audio signals.
The X1 Type is known as the 'across the line' capacitor as in a connection from Line to Neutral. These caps are rated for 440VAC and will pass a 4000V short test.
The Y2 Type is a Line to Ground capacitor and rated for 300VAC and will pass a 5000V open test.
I also use these Vishay X and Y rated safety capacitors across the AC switches to quench the arc and make the PL700B / PL700 Series II switch contacts last longer.
The UL spec for these capacitors in our application is .015uF and I use .01uF which is close enough.
Now for the good part: These caps are only $0.25 each when you but 10 or more using Mouser P/N 72-VY2103M63Y5US63V0.
Try 'em, you'll like 'em.
incredible...
Love Joe Bonamassa. Saw him on his tour about 2018-19. From my cell so not great video. Be sure to select 1080 res.
https://1drv.ms/v/s!AlFRDWiFYMK4hb9KbY0wgtcdHmDbbA
https://1drv.ms/v/s!AlFRDWiFYMK4hb9HYV0AJbcT7jwi3Q
https://1drv.ms/v/s!AlFRDWiFYMK4hb9JqBMSIMwc36B5bg
maybe one day he will play costa rica...i surely would go...
i think i am gonna contact him...
lol....
