phase linear 400
Vynuladikt
Northeast Iowa
I am confused with your description of the timeline. You mention C8 being wrong and you corrected it but it tested fine. What is the value/type of C8, and where is it in the circuit?
Even more to the point Gene, what was in that kit that you swapped components out with? Can you provide the reference designators for each component you swapped?
You may have broken one or more of the leads on the bias transistor whilst doing your board rework. If you break a lead and the bias transistor becomes 'open' as a result, all hell will break loose on the back wall. And in the process of taking out (damaging them) the 4 outputs, you may have opened one or more emitter resistors which will make the subsequent DBT test look fine when it actually isn't fine.
Vynuladikt
Northeast Iowa
Went back through the thread, C8 would not have caused that failure. As Joe mentioned it probably was runaway bias. Time to find the culprit and trace damage. Or better yet, get a White Oak board.
The old CRTs were high voltage, but much lower joules/capacitance. Read as a mild pop. The PL 400 amps with 80 volts and 5900 uF on each rail can be used as welders. Upgraded power supply caps with 10,000 to 15000 will disintegrate a screwdriver. But I guess you know that now.
100uf 25v...circled in pic...the top one i had reversed....
after recap....it played 4 or 5 seconds...then quit...was scratchy....
i noticed the cap reversed....i discharged the caps and switched it around...
has not played since...
You may have broken one or more of the leads on the bias transistor whilst doing your board rework. If you break a lead and the bias transistor becomes 'open' as a result, all hell will break loose on the back wall. You in the process of taking out the 4 outputs, you may have opened one or more emitter resistors which will make the subsequent DBT test look fine when it actually isn't fine.
here was the work sheet....i got one for the sx...much more professional and documented...
Vynuladikt
Northeast Iowa
I think it was possibly blown when it quit playing after 4 - 5 seconds. again, I don't think C8 could have played any part of the failure.
Shorted the capacitor plus and minus accidently one time. Scared the shit out of me.
my son had the bubble wrap the light bar came wrapped with...and waited until i was elbow deep into the 400....started popping the wrap....
he slept outside....i had to change underwear....my wife is still laughing...
or an error on my part ....i sent pics of both sides...of the driver board....
the dot map in the service manual has some bad spots...i did the best i could....
but, i feel i did somethiing on the 400c board...
is q6 the bias trans
both q6s check fine in circuit....i will poke around a little more....so far i see nothing obvious...
Don't know what a 400c board is, I use white Oak 14_20 boards. Anything else is old junk
it written on the back of the driver board...
Sadly the PL 400C schematic that I have does not match the board you have Gene so the schem I have is kind of worthless for helping you. You sure you have a 400C?
here is a pic of the board
looks like 3 versions???
i have the hifi engine version of 1976
with no inputs or outputs connected to the 400
and no transistors installed in the back plane...
the dbtester lights on power up and immediately dims....as it should....
the new light bar lights as it should....
that is a neat bar....the adjustment was the touch!!!!
havent had a chance to check much else....
thanks ....
