- Mar 6, 2022
thanks....i kinda got that after a bit....lol
i appreciate the help...very much
And now you still don’t know what is messed up on the control board that got recappedfor those interested....
4 tested bad....all on the right channel....all 909....
i understand you cant mix....
of course they stopped making these in the late 1800s....
i have a headache...
crap....
no... i do not...And now you still don’t know what is messed up on the control board that got recapped
well...i just put screwdriver across cap terminals...If you discharged them by shorting eachcap with a large resistor then no...if you shorted out the rails then yes..
the top cap was very minor...the bottom cap was a different story...took us 4 hours to get the cat out of that tree....Discharging the caps should not have any potential to damage the outputs. Hopefully you used a resistor anyway, or there would be fireworks.
Outputs generally die due to both positive and negative being turned on simultaneously, (driver trans/board failure or improper biasing) or shorted speaker leads (less likely). Driving to major distortion also.
Guess we were typing at the same time. There were fireworks.
you are right....i had been on it most of the day...was trying to finish...could see the end in sightquit being in a hurry, the caps will bleed down in a few minutes, your process needs work, thats not how to discharge caps
that about sums it up...never claimed to be a tech..As they say, "I know just enough to be dangerous"
Good God
