In the understanding of a circuit you need to know about Op Amp circuit gain designs. This is a non inverting op amp circuit and if adjustment is needed I would commonly put a Cermet trimmer in to work around the value that is in the circuit at the right place. R569 is not the right place- R555 could get a 68K resistor in series with a 20K trimmer and then you would have adjustment as you might need. The 68K provides a minimum amount of gain and then the wiper would take 68K to 88K allowing a lot of adjustment.
I would also get rid of the 6.3V cap C553 and put in a 16V fresh cap minimum.
First you offer a section of diagram and no telling what device this is from. You need to get the outputs from the circuit rather than worry about meter display first. Lack of getting proper output or test signals can be attributed to wrong measure technique or not correcting for circuit decay where it needs to be taken care of. Changing one thing in a chain does not affect the other parts but the voltage level might change which is what you apparently are after. Modifications that I do on decks have to have a good reason to do it not just because a adjustment can not be done. Like I was telling a trainee who is trying to calibrate a A4010S from Vietnam days, if you still have 60 old caps in the deck the calibration will not be possible but I am not knowing what decks you are working on.
Why get rid of 10V and 6.3V caps? Well first they are old most likely and then these voltage type caps have a high degree of failure to them and often times this is what the problems in a system are. My shop does not use anything less than 16 V caps. I do not allow any SMD parts in except for op amps which go into Walkmans.
I ALWAYS go up on voltage if I replace caps. Always.
I try to tighten tolerance is possible too, to get back to the design intent. I don’t have fancy test gear so I spend a few cents more per cap.
I always go up on temperature too. Generally, new caps “up-rated” end up the same size as their elderly counterparts.
just my case, after adjusting dolby level, output is not 400mV as it should be,
Yes, in my case it should be 545mV and +2.8db as a test tape I'm using is 200nWb and not 160. With 160nWb tape peaks should be at 0db. Problem was that it was more than 570 on output if I remember correct and peaks are at +5 and +6db, which I have to reduce.Sorry, Alex. At Dolby level, the output of these decks is about 545mV. The 400mV are for the 160nWb test tape and is something 2.8 dB below the Dolby level.
Exactly what I did.... Or 245mV @ pins 21, 22 of the Dolby chip (cx20187)...
Which is the correct way to adjust playback levels.
