RCA plugs / contacts
#23
Fugged if I know, Steve bought a bunch one time I used on all his stuff, I don't remember what series it was Joe..
#27
Just gigging Lee. Those are the Chinese knock off brands of WBT connectors on Amazon. You have to have a lot of brass to list your knock offs under the WBT name and part number.
At one time, I found the Chinee knock off of the Cardas RCA's but only saw them once, none since. They weren't any cheaper though.
#28
I know switchcraft are quality. We used them for all the “open” 1/4” jacks in our guitars. I also have one in my WP-2 headphone amp- they just work… forever.
Inhavent used their RCAs but I suspect theyd be fine.
I’ve used Neutrik (Rean) RCA panel jacks in my builds. Those are fine. I haven’t used their cable ends however.
Alex SE
Sweden
Amateur
#29
You are close to Germany, check out WBT...
Have checked yesterday, probably good stuff but not cheap. I mean, we're trying to find a balance. Something that will do a good job, will last over the time and is not Sci-Fi. Such a plugs obviously can't be find for a 1$. At the other side Amphenol seems to be one of those that will do a good job for about 2$/pcs, so 8$/cable + cable itself. Not cheap either considering to how many cables a one need, but can be acceptable as a one time investment.
#30
If you’re making a lot of cables, check the quantity pricing. Mouser at least lowers the price as you buy more.
And note that some colors cost less than others too. I guess it’s popularity but that’s what I saw. I for some in other colors for digital cable ends.
8991XJ
#31
I think their rca's are cheesy
Switchcraft is from before the era of cable needing to be jewelry and just does the job. Not a lot of extra metal. The extra metal brand is Canare and Connectronics both available from Markertek. They also have Rean which I have read good things about.
Those two extra metal brands are big connectors.
#33
Hey Jim
Any comment on the differences between the APCL and APCR series of Amphenol RCA plugs? Do you know what the big difference is?
