- Jan 14, 2011
- Gillette, Wyo.
Ahhh.....the ol Soniphase....
The 4592’s I got from you are going to drive these I am looking forward to them singing MarkI probably had 20 hours in the pair I made but it was well worth it, I have the BMS 4592 Mid and use them as midrange
Are you gonna use an active crossover and tri-amp or passive crossover. I tri- amp with a 700B driving the woofer and vacuum tubes in the mids and tweetsThe 4592’s I got from you are going to drive these I am looking forward to them singing Mark
I am going to tri amp Mark. It will be crossed with a couple of Rane AC-23 electronic crossovers. The Rane has a 24 db roll off per octave and there are 41 steps in the cross over frequency.Are you gonna use an active crossover and tri-amp or passive crossover. I tri- amp with a 700B driving the woofer and vacuum tubes in the mids and tweets
Jim you may be rightI was thinking that myself as I read Grappelsaw's post. Steep crossovers seem to suffer more from phase issues. Part of the reason the Thiel crossovers are so damn complicated (in addition to the sloped baffle).
And I further suspect you need fairly exotic equipment to identify it is happening. I don't know that you would pick up on it audibly, unless you could A-B between phase distorted and not phase distorted. The "ambience" setting on my boom box sounds pleasant and is using this technology to do so. So, it wouldn't necessarily sound unpleasant, but it would not be a faithful reproduction of the source (which is my goal unless using old receivers).
These crossovers I will use have the ability to adjust for the shift with time delays in each rangeDo any folks using steep slope crossovers have concerns with the far reaching phase distortion associated with steep filter slopes?
I have an Ashly XR77/18 3 way stereo crossover that I've had for 30 years and it still works like the day I bought it. With the Fastrac 400 horn with the BMS 4592 as midrange I have it attenuated it significantly lower than the woofer and tweeter because of its efficiency
New better results using dead short on inputsSo the King has new life
here are residual noise
A channel is left
B channel Right
1K across inputs and 8 ohm load on outputs.
two reading for each as lower numbers are at low rail and the tad higher numbers are at high rail
New better results using dead short on inputsView attachment 64684View attachment 64685View attachment 64686View attachment 64687
having great success on my resent 700B build I wanted to revisit the grounding topography of this wonderful amp. I applied the lessons learned and I am most pleased with the results. I will be guiding Spencer to apply this to his amp.
Right low rail 110uV
left low rail 208.7uV
right high rail 123.4 uV
left high rail 265.5 uV
