Made it yourself? I like! And...no, you are not measuring force with it, but comparing masses. It will show the exact same result on the Moon, whereby VTF will be only about 1/6 compared to the Earth, due to Moon's lower gravity. Measuring forces ain't an easy task.
My point is directed towards people claiming decimals at one end and speculating at the other. I don't mind, if somebody is anal about it, in fact I do appreciate it - just be anal the whole way! (buoyancy is only my over-the-top example):
1) VTF...if chasing the second decimal point, you must use some sort of a force gauge, not a weighing scale, or at least take into account the "agreed-upon average" gravitational acceleration on the face of the Earth is 9,81m/s²...the actual you don't know.
Hmmm, WTF seems the more appropriate term.
2) VTA
- do you know the cutting angle of your record(s)? If so, you surely set it for each different one? And why don't you?!
- record thickness...again, individual settings
- thicker/thinner mat...
- VTF/WTF...
4) azimuth...isn't there an expression about mirrors?...and smoke
5) anti-skating...eeehm...what?...where?...when?...why?
6) overhang, tracking angle...
7) matching an arm with a cartridge to get the desired resonant frequency...why is this so difficult?!:
- you know the stylus' compliance
- you know the arm's effective mass
- you know the masses of cartridge, shell, lifter, screws, shims and their effective masses
- you know the effective lenght
- now fill this data (don't forget the compliance conversion if stated at 100Hz) into one of the equations floating around, let it simmer for fifty years...et voilà!...an exact hit-and-miss ballpark aproximation of
a checkee in a baskee.
8) and what not...but to start the anal-journey on a solid ground...first of all: Go linear; a radial arm is flawed by its nature!
Let common sense prevail, pretty please with sugar on top:
- weighin scale is fine...no need for a really expensive one
- set VTF according to manufacterer
- get a test record, if you fancy some setting-tweeking, or wanting to verify the stylus and/or cantilever are mounted within specs
- keep the records and stylus clean!
- if you just want to taste vinyl for the first time...get a new plug-and-play (cartridge mounted and pre-set) turntable.
Lean back and enjoy the music!!!...scrapped out of vinyl grooves with a stone -
- I'll wear my precious records out by playing them...yada yada.
May the Hearing be with you!
Borut
Edit: BB, I see now you didn't make it yourself. Still like it.
