JBL 4 Way Build Questions
Mohawk
Ontario Canada
#61
An update to the thread, I have the drivers mounted and wired in the boxes and getting ready for testing..
Ill have some pics shortly....
I have been thinking about the 400 I have set aside to run the tweeters but that is double overkill.... ish....
What are the thoughts of using either a 200 or 300 ?
Any opinions out there on which amp would be better suited ?
M
#65
The 300 is a very good little amp. Bias trannies connections are unreliable and if a bias trannies goes, pop goes one of those unobtanium outputs, which just happens to be the same ones the mighty SX 1980 uses....good luck finding any...
#67
Even.less reliable. PL even recommended NO 4 OHM loads on it..clips asymmetrically... just a piss poor design.
You can cure the 300's problems, but not the 200's.
#69
Thoughts on upgrading and using a 200 series 2 ?
Had a PL200 Series 2 myself, had to replace just about everything in it and rebuild it including zorched traces on the PCBs. After rebuild, it was a nice sounding amp, like the 400.
The 200 and 300 were the red haired stepchildren of PL. Run fast and far away is my recommendation.
Both are scarce, mostly for a reason :).
Mohawk
Ontario Canada
#70
Getting closer to being finished.... Before I got into the vaneer stage of things I did some set up and listening of the drivers in the naked boxes and I am very impressed with the initial results ! The 15's were cut off @ 280 Hz and the 10's cut off @ 2k .. Just a starting point before I really get into the setup .... 20220124_195603.jpg 20220124_174053.jpg
One thing I may change is wiring the drivers in parallel instead of series .... I had to boost the DSP's output a lot more than the other channels to get the right initial volume as wired in series .... Thinking a DPDT switch incorporated into the binding post wired to switch from one to the other.....
4 ohm parallel / 16 ohm series
Hmmm....
M
pennysdad
In witness protection.
#71
M
Keep in mind, those JBL 2405 Slots are only rated at 40W.
pennysdad
#75
I was quoting the JBL "spec".... But I agree about the 8k cross... In post #1 posted that that's where I cross mine ...
I may tinker with that and try higher .... :rolleyes:
M
I use either 2402 Rings or 2405 Slots [actually 077]. I chop and change my points all the time. Active or passive.
I also fiddle about with their locations lots too! Like have 'em real high. Like about 2 metres higher than my monitors.
It just adds a bit of 'air', and 'tinkly' types sounds like chimes etc., just sound so spacey.
pennysdad
#77
Mine's running bridged into an 8 Ohm load [sub]. Has been for years now. At least they came with DC protect as standard.
Mohawk
Ontario Canada
#78
An Update to the dual 10" midrange build...
I decided to re-cone the 2123's while I was at it ....
After some preliminary testing I also decided to incorporate a Series/ Parallel switch ....
I'm thinking parallel performs best !
20220214_130031.jpg 20220308_213310.jpg 20220220_210153.jpg 20220220_205837.jpg 20220220_133259.jpg
Just playing around with the crossover fq' s and eq settings now....
15's 280 hz
10's 280 - 2K
Horns 2K - 8K
Tweeters 8K - 20K
#79
View attachment 63698 View attachment 63699 View attachment 63700 View attachment 63701 View attachment 63703
View attachment 63704 View attachment 63702
15's 280 hz
10's 280 - 2K
Horns 2K - 8K
Tweeters 8K - 20K
Parallel always performs better. With a series connection, your damping factor goes to hell in a handbasket. What you listen to is not real with a series speaker connection.
