- Jan 14, 2011
- Gillette, Wyo.
Not a speaker designer so I don't know...just curious if that's a consideration on that side of the cone..
Not a designer either but have done some experiments and a fair bit of reading. The short answerer is I don't really know but there will be some cancelation and some coupling. I would certainly dampen and stuff the box and since he has essentially a unlimited crossover to play with, keep trying to integrate the pair into the stack. Whether separate or combined enclosures, two 10's will probably be too much and I would try the single 10 myself but as with all things audio, YMMV.Not a speaker designer so I don't know...just curious if that's a consideration on that side of the cone..
Series ckt ? No... Essentially the impedance is added (summed) ... 2- 8 ohm speakers in series is 16 ohm load . 2- 8 ohm speakers in parallel is a
4 ohm load .
That’s the dilemma I’m in with my 15’s... 4 or 16 ohm total. I went with parallel 4 ohm as I needed/wanted the extra power. The 400 will be ~100wpc at 16 ohm, adding an extra driver physically adds 3dB also so maybe 16 ohm will have enough power? I would share their box, like I said, volume isn’t critical at these frequencies smaller is probably actually better. What are the speaker T/S parameters? That will tell you the suitability of those drivers for those frequencies... you’re looking for stiffer compliance to be effective as mid speakers. Box Fs not a factor at those frequencies...Yeah, that would be mine too. With no definitive info at hand makes that even worse. Well, ya know that each driver requires a certain amount of volume, having a separate volume for each driver would keep you from reconfiguring the cabinets if the common volume trick didnt work.
I would agree, unless you’re trying to use them down near their resonant frequency they don’t need much box. Those are a proper mid range speaker too, id probably run them 500-3k and see how that sounds. If you’re using a DSP you have easy flexibility too. You may want to call JBL and talk about on/off axis phasing at different crossover frequencies also. For too technical for me but I was advised of this and recommended not to vary too much from eminence’s recommended crossover points due to this.Have a poke around in the specs and let me know what you think ...
I agree with the smaller volume, Win ISD modeled it that way also ...
.25 ft3 gave a flatter and 1 db louder response @ 250-300hz compared to
a .5 ft3 box.... (ish...)
That is pretty cool. I have never seen a 10" speaker with a sealed back like that. Nothing even similar.I would agree, unless you’re trying to use them down near their resonant frequency they don’t need much box. Those are a proper mid range speaker too, id probably run them 500-3k and see how that sounds. If you’re using a DSP you have easy flexibility too. You may want to call JBL and talk about on/off axis phasing at different crossover frequencies also. For too technical for me but I was advised of this and recommended not to vary too much from eminence’s recommended crossover points due to this.
Here’s a pic of the 10” sealed basket mids I use in the shop, you can see there is virtually no volume...
