Dual-500 king of the Castle
Acetone is a chemical used to make products like nail polish remover and paint remover. Your body also makes this chemical when it breaks down fat. Acetone is safe in normal amounts, but too much of it could be a problem.
Does that help you any Glen?? :)
Thanks Perry
I still don’t like the stuff. To many years in fiberglass shops.
So conditioning the power caps for this bad boy. Things to note when doing this is to start at lower voltage and fully charge at that setting them increase over a few ranges to desired voltage and then leave at that setting a couple hours after they are charged and current is below excepted levels.
these are 35,000uf power caps so I pay extra attention to this process
4DB52B76-1841-475D-A3EF-A8D20FFFB9DF.jpeg4DB52B76-1841-475D-A3EF-A8D20FFFB9DF.jpeg4117B752-D81D-4FF5-88E3-5B8AA8CF71A7.jpeg
It does explain this strange nervous tick I have. :)
