quirkaudio
- Jan 11, 2021
the +/- 15v test points both measure correctly- and yes at 60v both channels measure 0v at pin 6
I have measure the voltages on Q7, Q8 and Q9 on the left (faulty) channel- Q7 b 10v, e 10v, q8 e 8.4v b9.3v. This suggests that Q8 is functioning (b-e=0.9v), however on the good right channel Q7b 0.2v and e 1.5v and Q8 b 0.6v and e -0.5v.
Q9 on the left b 6v and e 8.7v, where as on the right it is b -1.2v and e 0v
pin 2 on the opamp on the left is 0v.
All the resistors test OK and visually everything seems to be OK
could the bias transistor be bad and causing this?
thanks for you assistance
Peter
Some great close up photos of your control board build would be of great help Peter...it is hard to guess our way to success. Front and backside. Focus should be on the left channel.I have measure the voltages on Q7, Q8 and Q9 on the left (faulty) channel- Q7 b 10v, e 10v, q8 e 8.4v b9.3v. This suggests that Q8 is functioning (b-e=0.9v), however on the good right channel Q7b 0.2v and e 1.5v and Q8 b 0.6v and e -0.5v.
Peter
For starters, D4 is supposed to be a 10 ohm resistor. D3 is supposed to be the Schottky diode. D4 location is definitely wrong, D3 has to be checked.rear one to follow
Looks like some things were left unsoldered in the upper right corner.@Gepetto- I did get the phoenix kit, but not the 3 pin sockets, the bias wires do reach
here is the bottom photo
thanks for your insight
Best
Peter
Nevermind- I didn’t notice that the backside photo had the connector side up.Looks like some things were left unsoldered in the upper right corner.
so one step forward, two backward.
The original 410 pre drivers all measured OK, however, when installed, the 10ohm resistors want to provide magic smoke and the current draw hits 1.5Amp plus - so is the MJ15022G a decent replacement for the 401's?
There is also the speaker protection board installed- and relay not engaging (as expected)
Thanks again
