PL 400 series 1 XPL910 questions
What is the best way to attach the small heat sinks to the TO92 transistors on the WO Board- would a dab of hot glue suffice- or should I rely on the mechanical grip? The heat sinks all needed a slight adjustment to fit the transistors, and I wnat to make sure they do not come off inadvertently
Thanks
Thanks
Friction fit Peter. They slide on. No glue
