- Jan 14, 2011
- Gillette, Wyo.
So....what are you asking?
Phanatic, how do you route the preamp output to four PL700B amplifiers?Destined for another audio rack when I have the space.
....I can go to about 75 percent before you start to hear it outside. i built my shed with 2 X 6 walls and stuffed them with R15 pink fiberglass insulation. Russ.
I'm gonna order me a dozen tri-axles full of sand...i like the idea...
looking to upgrade my 5000 tuner with new festoon style led lamps. Blue is preferred color. 7 volts AC available, 12 volt .15 amp bulbs currently in use.
Thanks
Russ.
Yeh, that's how I'd do it.![]()
Do you have three phase with a distribution board to handle the 'slight' load... or do you just plug it all into the one socket?
Just messin' with ya of course.
I used to run something not too dissimilar back in the day although a little more rock'n'roll both at work and at home.
