- Jan 14, 2011
- Gillette, Wyo.
A 21196 was shorted in the right channel..
The emitter resistor fuse...How could I have a shorted output with an intact rail fuse?
This must be your amp Lee...![]()
Yeah, just a little to far to the right.
Joe's engineering has made taking out an output a lot less painful. Not near as much collateral damage..
Lee, just replace your .33 Ohm resistors with 1 Amp fuses from China, they are probably close to 1/3rd of an ohm...For you Lee, I should probably consider reducing your emitter resistors to 2 watters...![]()
"Now that's funny right there, I don't care who you are..."I will do a special backplane version for Lee that has fuse clips in place of each emitter resistor...
