scottcampthomas
- Apr 9, 2021
What is the cost (parts and labor) to have a qualified tech totally upgrade the sonic performance of my perfectly functioning but all original PL 400 ?
Oh, yeah... those, too.And meters will remain...
You can’t resell it for what you put into it, but if you want to keep it for a long time for yourself, it still makes a damn fine amp.If perfectly working, I would just put a DC protection board in it, 400s are not worth upgrading, unless it is of sentimental value.
...shit!Oh and knobs
At minimum, new outputs all around and capacitors. DC protection should be mandatory even if you do nothing else, and do it first.Mark is right, you will have a world class reliable amp, if you are keeping it then may be worth doing. However you must consider the cost, the cost to upgrade a 400 and a 700 is about the same. Most will buy a 700 to upgrade. I have a full WhiteOak 700B and a nearly stock 8 fin 400 with DC protection, and new output transistors.
Is that what we're getting on the 400? I thought it was somewhere between 230 to 250.With the rebuild you will be getting 250-300 Watts per channel.
Mark, it is hard to measure. Mostly, I grab a single channel RMS Voltage at the speaker binding posts with the full input level of 1.0 VRMS at 1KHz. Then I use Ohms law to calculate power into 8 Ohms. Oh, and you have to ensure the supply voltage at the outlets is 120VAC (no less than 117VAC).Is that what we're getting on the 400? I thought it was somewhere between 230 to 250.
I don’t like excess volume, either. At 63 years old, my ears are still pretty sensitive.I agree, upgrade that 400 when your ready. You'll have a wonderful amp that you can pass on to the next generation. I have 2 full WOPls a 400 S1 and a 400 S2. Both play way way louder than I'll ever need. I have yet to go past 3/4 volume, too damn painful to my ears, my dog, my cats, my tropical fish in the tank.
