- Oct 15, 2014
- ---not quite right
Hmmm she’s acting up on me... right channel again. Got three rows of outputs in then the bais jumped to ~600mV and the bulb came on dim. Seems if you fiddle with the output retaining bolts on the (from inside the amp) left row of the right channel the bias will jump from 220-600mV. Stripped it right down to drivers only and she went back to the 20-30V bias right channel. I pulled a pair of RCA410’s from Linda and swapped them in and she went back to 220mV with no outputs. Put the first row in and back to a dim bulb and 600mV bias right channel. These are new 2SD555 outputs and I swapped a few different ones in.
I’ve been looking at the back plane real close, moved a few emoter resistors away from screws, generally looking for anything that could be a problem. There’s a diode from the collector bus bar to the emoter resistors that looks like it’s been hot but other than that not seeing anything wrong.
Any suggestions? Was going to try soldering in the drivers on that channel and if that solves it I’ll gut Linda for tranny sockets as she’s getting White Oak back planes...
