The duration of time the amplifier is on seems to account for the voltage differences across R608. It's not stable. I re-checked immediatly after switching the power on and the meter read 49 volts. Ten or so minutes later 47.8 volts. Five minutes more 48.5 volts. A further five minutes 47.6 volts.
R632 measures 9.6 ohms
R633 measures 9.2 ohms
Regarding the TO3 output transistors, I can only say that the device I used failed to identify two of the eight as BJT transistors. The other six were identifed correctly - BJT transistors which meant good or so I thought. The only other method I can use is a DMM. More time consuming which was why I purchased that multi tester.
The way you phrased the last line was my subject question. If Q001 is on top and Q003 the bottom, then I have installed them wrong. I have the two transistors on the bottom.
I thought this was the orientation so installed transistors at Q002 and Q004. I have them side by side not above and below.
Q001****Q003
Q002****Q004
But this is layout instead? If so, then I currently have one transistor at Q003 and the other at Q004.
Q001****Q002
Q003****Q004
