Did you clean up the attenuator potentiometers or are they new, they look great!
For the re-lube do you use a heavy grease to give that damped feel? What lube do you use?They get disassembled, inspected and cleaned/re-lubed if they pass inspection
molybdenum reinforced bearing greaseFor the re-lube do you use a heavy grease to give that damped feel? What lube do you use?
I think these were CTS pots and the older ones were made better than the ones made today. So I agree it is worth the time to inspect, clean, and re-lube them. I have a box full of them. Maybe I should check them out.
I have a couple of small tubes I filled from a 5 gallon pail of "Extreme Pressure Grease" Mil-G-83261, we called it 'Jet Black' in the Navy. Sniff probably remembers it. If I open a tube here in FL, some of it will eventually get on the wall of the house in Sterling, MA.molybdenum reinforced bearing grease![]()
Thanks for the photo.I have also had excellent luck with these
I put a set in Brent's amp in January and he uses it every day with no issues.
I have used those pots, Mouser P/N 652-PDA241HRT02104A2 except with the last two digits being "B0" instead of "A2" for a Linear Taper pot. instead of an Audio Taper pot. I have never found a parts list for the PL700B, but the PL400 II and PL700 II parts lists show a 100K Linear Taper pot.
OK, been putzing with the hybrid WOPL. Still gotta work on the lighting below the meters but IT LIVES..... Has any knucklehead done Red White and Blue lighting????
The picture doesn't do it justice. The cameras still don't like LED's
Sniff, have you ever had to replace the little plastic Power and Display pushbutton covers? Is there a source for those? I ask because the Clair Bros Audio amps have very corroded and pitted surfaces on the pushbutton covers.
Massively Awesome Perry!, You have definitely outdone yourself with this special WOPL...700B Series II QWAZY WOPL rocking out. added some volume pots, and reworked the LED's to get the filters lit. Just need to do some adjustments.
View attachment 46035View attachment 46036View attachment 46037
