Dixon meter studs end up being very close to the bulk cap buss bar and aluminum retaining plate, easily shorting out if care is not taken. Clearance can be gained by pushing the cap bottoms towards the left tight against the chassis wall and rotating the caps which lowers the copper bus bar away from the meter. Additionally, the aluminum plate can be filed for more clearance, and plastic insulators added to the studs. Would be a real shame to get almost through your build and then overlook this.
