Oscilloscopes - Questions, Comments and WTF? (and NOLA too!)
My god... I just read this whole thread !!! My little brain blew plum up man !!!! WOW ! CAUTION !!!! This thread is not for HILLBILLIES !!!!
WOW!!!! You read a two page thread!! WOO HOO!!
Don said some good stuff. I quote:
"Ground loops between signal generators, a scope, and an amplifier can destroy an amplifier including the P/L's. It's essential that the amplifier input and output are not both grounded to the scope via the ground on the generator. Since I use the external trigger from the signal generator which grounds the scope to the generator, I lift the ground lead between the speaker cables and the scope input. The dual banana jacks on the speaker cables make this easy. I also lift the ground wire on power cord for the scope."
115VAC
For the reasons mentioned above, the amplifier input and output should never be grounded together (this may create a ground loop that acts like an antenna for noise). The 115VAC power ground from the wall should be connected to the chassis of the amplifier. This is simple and straightforward. In the olden days, house wall plates did not have a third wire ground connector. My condolences to you if you live in one of those houses. Homes built properly after 1959 had grounded wall outlets and it became a NEC requirement between 1965-1969 (phased in). Unfortunately, appliances and stereo equipment designed for 2-prong outlets were not eager to change their designs for "house builders". In plain terms, your amplifier (at least; and all other components, at most) should have a 3-prong plug and cable with a green wire, the longest of the internal connections firmly (toothed lock washers) bonded to the metal chassis. This is so that if the power cord gets pulled out of the equipment, the ground wire is the last broken connection.
This does not create a ground loop, all of the devices plugged into your home are grounded together at the electrical box and that line is grounded by a rod buried 4-6 feet in the Earth, or should be.
For the o'scope, most modern o'scopes have a switch mode power supply and operate on 48-72 volts. Defeating the grounded isolated power supply should not make any difference in the display. Older (tube) o'scopes can operate at high voltages and the CRT nominally takes 6-9KV from a separate power supply. Some o'scopes feature a 'ground lift' to isolate the circuitry from the supply voltage; that is not the same as cutting off the ground pin from the plug or using a 2-3 prong adapter. If your o'scope has any accessible metal parts, ground the scope for safety.
Amplifier Inputs
The input connections should go straight to Joe's board, isolate them from the chassis and each other (remove the copper plate between them), and connect them, tightly twisted or bu Coaxial cable, to nothing else except the volume controls, if desired. Check the pots to ensure none of the connections are common to the shaft or body of the pot (they should not be). In other words, input common is not connected to chassis ground.
Amplifier Outputs
The amplifier output common or black wires, like the input commons, should not touch the chassis - anywhere. They are properly terminated at the black speaker jacks and originate at the "Star Ground," the common ground for the circuitry, not the chassis ground. This will keep the o'scope and the outputs from sharing a ground. The "Star Ground" for our Phase Linear amps is the bus bar between the two power supply capacitors. In these amps, I place a 2.2 Ohm 1 Watt resistor between the "Star Ground" and the chassis ground (one of the short terminal strips on the back wall between the rows of output transistors). This allows the "Star Ground" to 'float' above the chassis ground and send noise or hum to ground (Earth).
So it looks like we need to modify our build to this and ground 120AC to chassis.
This is not what we have been doing but sounds like an idea
Remember, the last time a hillbillies mind was really blown, they discovered oil and moved to Beverly Hills...
Don,
I see that you have a Loftech TS-1 Audio Test Set.
Did you by any chance get a copy of their book:
"Audio Measurements: Their Importance and How to Make Them" by Larry Blakely, John H. Roberts Phoenix Audio Laboratory (Loftech) 1982 87 pgs
This book was a free companion piece for the Loftech TS-1 audio test set or could be purchased separately.
I've been looking for a copy.
Ed
ED,
Attached is a high res scan of my original manual. The original was 8.5" x 11", folded and stapled in the middle. It took quite a bit of editing in Acrobat to get it in this form.
ED,
Don,
Thanks so much for making the copy!
The Loftech TS-1 is a nice handy/dandy device that can fit easily into any sound-mans toolbox.
Thanks again!
Ed
Ed,
Are you able to reciprocate with a Sound Technology 1400A manual? I have 2 of them to repair.
Don,
Unfortunately I don't have anything on the 1400A except an old Sound Technology price list from 1984.
Demian Martin on the diyaudio forum is probably your best bet at the moment. He has amassed a large collection of audio test equipment over the years. If he doesn't have it, he may be able to point you in the right direction. He could probably also fix the 1400A's for you. He has a lot of experience repairing and upgrading signal generators and distortion analyzers as well.
By the way, I also saw your post on the diyaudio forum.
Here is also a link to a youtube video with Demian Martin and Jonathan Novick (former top sales guy for Audio Precision):
I suggest that anyone else interested in distortion measurement and test equipment check the video out as well.
Ed
Thanks for that vid Ed. Good info in there...
I'm kicking myself for not attending those 'Burning' events when I lived so close.
Hard to beat that price. There are some cracks for some of these scopes that xtend the badwidth etc. The downside of them is the trace is a joke compared to a decent analog scope. In that I mean the trace is so fat you miss high frequency oscillations riding on the waveform. I have a 50 year old Tek 503 whose trace is far superior in that regard to the 50 mhz 4 channel Rigol I've got.
Getting one that hasn’t had the stuffing beat out of it is tough, and yes- they just don’t make ‘em like they used to. This original post is from long ago, so I had a while to figure out what tradeoffs I’m willing to live with. Sure, not the best one out there, but it should fit my needs.
