TapeHeadOne
Lights out Here. First thing tomorrow !
Hi PeteI made following measurements :
Turning both bias pots fully counterclockwise, I measure 240 mV on the left channel, and 120 mV on the right. Setting the left bias at 375 mV, and the right pot in approximately the same physical position, I measure 168 mV, which I kind of expected. Q6 L and R are around 78V at all times.
Hi Pete
Q6 C and E should be hovering around about a volt or two around zero start by trying to figure out why you are seeing 78v
