Jimmy's 400 Rev D in for Warranty
Australia
#21
The frustration continues...got a blizzard comin, all my wells tucked in for a 3 day storm if it gets that bad. 9- 20 Inches of snow and 60 mph winds....this should be fun.
Jut a slight movement of the upper right corner of the board....
Good luck Lee, Hope you and Jani are ok :)
#22
Update....
After shorting out a low voltage regulator TO-220, and rebuilding the entire low voltage section, I am back on the original problem.......probe slip...
#24
Joe, do I isolate the base drives in a quasi D the same way I would on a full comp?
#29
Preserved for posterity now.
Control board debug instructions
These are quick checks you can perform on your control board to ensure it is regulating properly.
Quasi-Comp Configuration, all PCB artwork revisions
  • Pad references that follow will include L or R and will depend on the channel you are testing. The L an R are left off of Pad and component references for simplicity.
  • Detach and tape off wires going to Pads 9, 8, 6, 4, and 3.
  • Tack a jumper wire between Pad 3 and 12.
  • Tack a jumper wire between Pad 8 and 6.
  • Tack a 47 ohm 1/2W resistor between Pads 9 and 6.
  • Tack a second 47 ohm 1/2W resistor between Pads 4 and 6.
  • Bring up on DBT and Variac and ensure that the output on Pad 6 is zero or no more than 15 mV.
  • Check that you have B+ on Pad 11.
  • Check that you have B- on Pad 12
  • Ensure that the voltage across each of the 47 ohm 1/2W resistors is less than 2V and the voltage on the 47 ohm 1/2W resistor tacked between Pads 9 and 6 varies as you adjust the bias potentiometer.
  • If all good on the control board search for your problem on the backplane or backwall.
  • If not all good on the control board, use this configuration to debug what is wrong with the control board.
Full-Comp Configuration, PCB artwork Revision D, E and G1
  • This set of instructions assumes you have the White Oak Audio Backplane Kit installed.
  • Tack a second 47 ohm 1/2W resistor between Pads PNP and 6.
  • Ensure that the voltage across each of the 47 ohm 1/2W resistors is less than 2V and the voltage on each 47 ohm 1/2W resistor varies as you adjust the bias potentiometer.
Australia
#34
I would read his post in full 3 times then follow step by step. Variac? Dim bulb? Eh?
#40
Measurements
Left channel
Plus lead on 6 neg lead on ground----------40mv
Plus lead on 9, neg lead on 6--------------+.566vdc
Plus lead on 4, neg lead on 6 ------------ -.218vdc
Adjustment range on pad 9 to pad 6 47 ohm is +.594 vdc to +.841vdc
Right channel
Plus Lead on 6, neg lead on ground----------36 mv
Plus lead on 9, neg lead on 6--------------- +.571vdc
Plus lead on 4, neg lead on 6--------------- -.238vdc
Adjustment range on pad 9 to pad 6 47 ohm is + .572 vdc to + .813 vdc
