VSAT88
There is one of these posts for Fisher parts over at AK and I am damn glad we have one here now for Phase Linear, thanks !
			I’ll buy one from ya...I'm plan to get a lot of 10 of these:
https://www.ebay.com/itm/382516589955?ul_noapp=true
They'll be about $15 shipped. If anyone is interested let me know. I have not pulled the trigger yet, but I'd like two or three for myself.
I know this is an old post but does this bridge rectifier and snubbers work on the 400 and 700s? Thanks for the work on the database and everywhere else.50 amp bridge rectifier-----------905-KBPC5006T
Snubber caps for same-----------5989-400V.01-F
Thank you Lee, trying to learn and join the group, going to start ordering pieces and get going on the amps when work slows down some this fall.yes....
Looks like a great idea, truly creative.did anybody ever find the part number for the P-straps for the bias tranny's?? This could work rather well, He kind of butchered it but taking your time and a piece of heat shrink and it should work rather well. Thanks
Those ring terminals look to be made of copper, the p-clamps are aluminum. Heat transmission may be a little different. The p-clamps have the flat of the case down, not up, so watch the transistor pin order.did anybody ever find the part number for the P-straps for the bias tranny's?? This could work rather well, He kind of butchered it but taking your time and a piece of heat shrink and it should work rather well. Thanks
You buy junk 2SC type transistors on ebay and salvage the Pstrap and throw the original transistor away. I landed 25 junk transistors a while ago for low money that I have in a pinch.
But every amp has the originals, where are they going?
Mazel tov on that...I am going to try plastic transistors for the bias circuit.
Can’t believe the resistance on this one. This site is all about find new and improved but not for this part. I still going to try themMazel tov on that...
If a specific part is indicated by the circuit designer, they do it for a reason. I wouldn’t stray from what’s in the design.
Dual 500Trying it on a WOPL or an old beast???
