The Smoked 400
#81
Out of circuit , same result. Should I reattach the free end of R76 before applying power w3ith new Q7?
For some reason didn't check C-E in circuit, just B-C, B-E and reverse polarity...jeez..
Yes reattach R76 and try the 22 ohm setup again.
Yeah I figured you might have just measured the junctions and not the C-E. Common oversight. That poor transistor was sucking all the base current from the output transistors when the upper side shorted out. It could not win.
#86
And are you still just on the 22 ohms? what is the voltage across each 22 ohm resistor? Try going up to ~100 ohms now on each of the test resistors.
#87
Protection circuitys are still disabled. .000 bias. Voltage accross 22 ohm resistors coming up..
#89
The voltage across the 22 ohm resistors is currently the bias Lee. You should see 0 at the real bias resistors as you noted.
#90
Ground reference at Star ground
9L---+.648vdc
6L-- -.017vdc
LPNP -.647vdc
9R--- +.595vdc
6R--- -.012vdc
RPNP- -.625vdc
#95
9L---+.648vdc
6L-- -.017vdc
LPNP -.647vdc
9R--- +.595vdc
6R--- -.012vdc
RPNP- -.625vdc
Excellent Lee. If those 9 and PNP (L/R) respond to adjustment of the bias pot then it looks like you are ready to hook things back up again.
#97
Go to 100 and then the heat should go down on the 2 transistors which will give you more time to work with it.
#98
We have heat on all 4 pre drivers now. Hang on I'll get some 100's in there. How much response are we lookin for??
