Parts Database
MarkWComer
Gaston, SC
#82
Two items that I'll have to let you know if they're suitable for the WO chassis:
1-15R "fan only" AC outlet: 562-738W-CX2-01
DPDT "direct couple | normal" slide switch: 611-S202091SS03Q
Coupler caps for above (63v 1µf): 505-MKS21.0/63/5
All Mouser PNs.
(I may have to edit this later if something doesn't work...)
Oops- the switch in the chassis I have is DPDT, but a DPST would work- two legs aren’t used. I’ll find something else...
DPST switch: 629-GF325
MarkWComer
Gaston, SC
#83
MarkWComer
Gaston, SC
#85
I always have ~1000 in stock Mark.
I hate bugging you... I hate bugging anyone! And I won’t until I run out of options...
But, yeah, I was gonna post a “can I borrow a cup of sugar” message and return them when my order came in.
I still have the IC that someone sent for the PL400 DC circuit, and a handful of germanium xsistors for the now obsolete version of the driver board. When the 400 had the blowout I bought double the parts required to fix it, so I’m a parts hoarder.
#86
Shipped, you should receive in a few days time.
MarkWComer
Gaston, SC
#88
The new WO chassis has thicker metal and the ears that lock this part in will need a little modification. This appears to be the ONLY chassis mount AC connector of this type on the planet.
#89
Figured that based on the spec sheet. It is the only one I located Mark after searching for options.
MarkWComer
Gaston, SC
#94
MarkWComer
Gaston, SC
#95
Heyco strain relief plug SR 14-4
Mouser 836-1120
(Used in most stereo components)
#97
They work well. Just need to jumper across to use both internal switches so the load is spread across them both. That and a snubber cap and the'll last for decades. I use them all the time and yep, pricey for sure. Lee showed me that trick...
Wheel-right
I'm plan to get a lot of 10 of these:
https://www.ebay.com/itm/382516589955?ul_noapp=true
They'll be about $15 shipped. If anyone is interested let me know. I have not pulled the trigger yet, but I'd like two or three for myself.
I'd be interested in two of these if you decide to go ahead. Got a 700 II now and a friend with a 16.5 Concept so probably a good idea to have a couple around. Rob
