grapplesaw
The cut sheet and the picture indicates a 220V circuit. Is that what you bought?
I attached a cut sheet for a phase angle controller chip I've used before. When used with modern triacs there is no switching noise and no snubber needed. The drawing shows an electrolytic cap CS with the wrong polarity. Builder beware.
PLmavenman has a stalled project to use a microcontroller softstart.
Don I ordered 110volt units. I will study what you posted. For now I will put together the unit as a common rail supplied but the two 1000VA toroidals. I wil use two soft starts, one for each transformer. Then we will see if changes are needed.
