 - Jan 14, 2011
 - Gillette, Wyo.
Yep, that's a choker......
			Joe,
I will want some as well.
At a minimum (1) set of (4) black anodized aluminum heat-sinks to fit either a 700B or 700 series II amp.
I am assuming these are the same dimensions as the originals?
If I buy several more sets at the same time, can you combine shipping and save me a few dollars on shipping?
Thanks!
Ed
Would copper heat sinks eliminate the need for
cooling fans on the 700 at elevated SPL's?
No copper heat sinks would not eliminate that need.
If I get enough interest, I will get these PL700 Heat Sinks made up.
Aluminum Anodized price per set of 4 is $113 including shipping
Copper no finish price per set of 4 is $400 including shipping
Copper with Black Oxide is ridiculous so will not even give you that price.
The 1-3/4" stock heatsink should fit inside the 2" so that might work....
