- Sep 13, 2016
- Atlanta, GA
- ---there is no replacement for displacement
I have measured and 2"x 6" X 1/16" rectangular aluminum tubing should work. Just cut off one end at stock length or leave them long at full 6". I am going to build a set. The high heat sensors will have to be mounted prior to assembly with counter sink screws from the back side. I am using six of these in my monster mono build in 1/4" wall. Say tuned. It's a little down (3or4) on my list. Need a full comp 400 first. Then finish referb of my original 700 series one then after that. In the mean time I am ordering the heat sink stock
Thats exaxtly right, was going to do the exact thing only with 1/8" aluminum 2" x 6" rectangular tubing. The 1/8" thick will slightly crowd the backplane board hardware but can be clearanced manually. A good carbide blade and some lubrication wax on a mitre saw makes quick work of cutting extruded aluminum tubing, been fabricating motorocyle racing parts like this for years.
