WOPL dual 500
All the wiring is finished. All ready for the first power up through the DBT. If that goes as it should then I will load the drivers. Yes it is upside down. So tomorrow will be fun.
That's a lot of point to point there Glen!! Good job man!!
And all this time I thought it was down side up. :roll:
Agreed Lee - that point to point wiring is sure busy. Cool stuff Glen.
It's alive
Initial power on ok. Now have to rework the To-3 screws as they are shorting to to ground. I guess I am off to buy some nylon washers tomorrow someplace. The first build I let them flop about while I loaded the out put transistors and that was funky so want to improve that job setup.
It is a bit busy in there But it has like 50 miles less wire in it than original the build by PL. and no Ac wires bundled along with low and high voltage control and rail wires. I moved so much in this it's hard to say it is even a PL design anymore.
The control board will be about 2" above the output transistors. I have added a few extra rail caps similar to Joe's design.
I have left off the fly back diodes as per the original factory built full complimentary amps I have.
I have left off all the ferric beads. I want to find out if they are required when running Joe's setup
Ed and I were talking about the lack of ferrite beads on this build the other day Glen. It will be nice to know that little tidbit...
I guess the WhiteOak design doesn't use any ferric beads in the 700 so got to try it out.
Ed and I believe the fly back diodes are not required allthought most full comp designs I have looked at have them. Again we will see.
The first one I built has three ferric beads per rail. The full comp PL 700 have one per rail and a quassi only has one on the positive rail. The WOPL setup has none. I put one per rail on the C-500 build only to be safe. I have not idea if they are needed.
Lee when I blew up a few drivers on the quassi dual 500 while driving in the 10-40 k area with about one watt power I did not see any parasitic distortion but the amplitude looked to be rolling off as it went higher with all thoughts beads in there. I need to revisit this area of inquiry. Got to set up a higher range on the Sectrum Analizer I have on the computer to observe it better.
Since we started using the backplanes, I haven't tried to kludge a ferrite bead in there. Don't think you could. The only 700 stocker that I wired from scratch, I left out the beads because I was using Joe's board. Didn't have any problems, and I was using the 96's.....
Do not remove the flyback diodes, bad idea.
Why is that a bad idea Sir Joe??
They are there to prevent external inductive kick from exceeding the rail voltages and thereby exceeding the Vce of the output devices. It is not unusual to get many hundreds of volts inductive kickback if you develop an intermittent connection of your long wires to your speakers that the amp is pumping current into at the time. Most woofers in your speakers have an in line inductor in the crossover that add to the inductance of your speaker wire.
While in normal operation, these flyback diodes do nothing. But in the event of abnormal operation as described above, you will be glad they are in there.
PS: Don't cheap out, put them in...
I would like to clarify......
I posted a reply to this subject many years ago on the internet:
I spoke to Dean about the flyback diodes (D107 and D108) last night used in the Phase Linear 700 series II amplifier. He also concurred with me in that they were never used in the either the 400 II or 700 II fully comp output amplifiers and most schematics have errors.
(NOTE:The schematics referred to here were the 400 II and 700 II fully comp amplifier schematics and PRO700 schematic which show flyback diodes. Whereas none of the fully comp amps actually had them installed in them. There were other errors as well.)
As to why they were removed.... "probably because they were really not needed in the first place or were of little value".
(NOTE: It was Dean who said this not I. Only someone like Terry Pennington and Mike Frost might know why they were removed and Mike recently passed away.)
With regard to the flyback diodes; I have never suggested that anyone do anything other than what was factory approved or factory practice.
I am not an electrical engineer. Nor do I try to pass myself of as one.
Ed
Me either Ed, but the term. "flyback" makes sense now....
Ok they are going on tonight. Easy to do
Lee I have always questioned the location of these beads anyway. My simple mind thinks they should be on the base between the prediver and the rest of the outputs. Not in the middle of the string of outputs
From what I've heard Glen, they put them in the place that did the most good. And that it wasn't always the same place. There was consistency where the factory put them, but I remember Ed saying when upgrading the outputs, that it could vary where they worked.
It's alive
With Joe's advice I have added the fly back diodes.
the job is finished. Time for testing it out. All transistors are bolted tight,soldered in. I have run a small signal with DBT light powering it. It has a nice sine wave both channels. I will heat it up to full rail voltage next then see what the AP tells me.
More photos
