Marantz model 18
calman46
MA
I'm looking into the possibilities of making a power transformer for my model 18 . I have the original E & l laminates . There are no AC voltages on 18 schematic but I'm told I can use the the ones on the model 19 . The primary on the 18 was two coils in parallel , I was going to use 1 . Its the secondary that raises issues ,as it is drawn all the taps share the same CT is that right? I may omit the HV winding for the scope (transformer's Achilles Heal ) there is an work around for adding another transformer (looking into it) . Do you think its feasible to make one ? I'll post the schematic shortly . Thanks
Go back to your post and click "Edit", then double click on your picture, there is a box you can check for Large picture. Were all old with bad eyes.
Are you sure the numbers written in red are correct for your AC Voltages? I't doesn't look right to me.
Are you sure the numbers written in red are correct for your AC Voltages? I't doesn't look right to me. One side of the Bridge Rectifier (red wire) says 25 while the other says 15..... Hmmmm according to the drawing of the transformer, those should be really close. And is that 360 VAC on the anode of that diode??? Which is connected to you 6.3 VAC??? Naw
I do believe on your secondary, the same color wires should be pretty close to the same. The transformer looks to be balanced so if the reading you have written in red are what you have on your amp, you got BIG ISSUES.
calman46
MA
The bridge has 25.5v on each side ,just the way I made the 2 . These AC voltages are from the Model 19 schematic . I'm told its the same transformer. I don't have a transformer in unit,I just have the iron from it. A so called rewinder told me he could wind me a new one (HV was out on mine) but after he ripped all apart he said he couldn't do it .
Just about anyone of us could have done that :)
The leg with 360vac can't be right. Even a WOPL with 500 watts ain't that high
That would be a tough job getting the secondary right. A lot of shit if you don't have all the winders notes available.
calman46
MA
right the 360AC winding is for the scope . I want to make just the power transformer for the unit . There is work around for adding another transformer for the scope . What I don't understand is all the other windings share the same CT. Its drawn like one winding, how would you where to put the CT? So could you make 3 different windings each with a CT and then connect them all to G ? Or are the Blue and Green windings really center tapped . Finding a 18 with a working scope is rare ,most HV winding have burnt out I'm told.
It's drawn like one winding because it is, the different voltages are where a tap is brought out. You'll notice two SEPERATE windings on the bottom of the drawing. The center tapped windings will be measured with one lead of your meter on the center tap (ground). That's why you see a blue on each side of the center tap, and green etc...
And I could have lost it long enough for you to find and buy the actual part.
No thanks needed, it's a natural talent. :iconbiggrin:
oldphaser
Marantz 18 Schematics & Service Bulletins
Here are some schematics & service bulletin obtained of the internet.
The transformer listed as T1 indicates a part number of 52-1000.
The model 19 service manual lists the power transformer T2 as part number 252-1009
https://www.manualslib.com/manual/889073/Marantz-19.html?page=73#manual
https://www.manualslib.com/manual/889073/Marantz-19.html?page=68#manual
View attachment hfe_marantz_model_18_schematics.pdf View attachment hfe_marantz_model_18_service_bulletins.pdf View attachment hfe_marantz_model_18_service_en.pdf
calman46
MA
This is all great info guys and I appreciate it ,but I have all this .I need to know how to add the CT to the windings. If I was to make this multi- tap winding would add the center wire to the coils as I wound the different windings ? So the center taps would be one wire connected to the center of each winding . Or make separate winding and connect all CT's together . What do you think
