- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
Last few days, when I crank the WOPL, I noticed weird sounds coming from the tweeters in both speakers. Kind of like a micro second metallic high pitched click but it's only on certain notes. I don't use tone controls, loudness or anything, just flat response out of the Perreaux preamp. I don't think I have hurt them since when I turn the volume down, there is no weird noise and they sound normal
I am not a huge fan of the horn bullet tweeters so I wondered what would be a good replacement that will go in without any sawing or any type of visible modification of the existing holes and that can handle the power
I may just pull them out for now because once you put the gas to these, the dual mids in each seem to compensate, maybe because they are higher mid frequency capable?
I also may just move these in the garage for now and put the E-712s back in service. The E-712s are a much better sounding speaker in every aspect and can go lower then the D9s BUT they only handle 300w vs the 400w the Earthshakers can deliver. The tweeter is a soft dome in them
