 - Jan 14, 2011
 - Gillette, Wyo.
You need AC to feed the DCP from the rectifier, not +....
			The DCP requires an AC feed from the rectifier, a DC feed from the + rail, and a Star ground. The wire from the rectifier has to be from an AC post, not the DC posts....
Okay, so either transformer post, and just that single wire from the rectifier?No, you need to move it to one of the posts where the transformer secondaries is soldered to...
Okay, I went to the website and reviewed the installation material. From what I can see, the only problem is that I attached the AC lead to the wrong post on the rectifier. My white ground wire is soldered to the buss between the capacitors. Am I still missing something?Yep, and the Star ground and From the DC+ rail feed from the backplane. Have you been to wattsabundant website and downloaded the installation instructions??
The backplanes are in. I'm still waiting for the control board. Joe said he's pretty busy. I'm sure he'll get to me when he can. But I'm referring to the instructions that come with the backplane kit. It says to install the first row of drivers and Variac and so forth. Am I mistaken, regarding the next step?You've got the backplanes and control board in?
You are not mistaken Scott. Check out the backplanes using that bring up procedure.
Okay, thanks. But is there any source you know of that has any more information on the procedure. For obvious reasons, I'm a bit anxious about putting power to anything for the first time.
This is pretty specific Scott.
With the connections to the control board all taped offso they do not short out to anything (both the bottom row of 10 wires and 3bias connection wires per channel).
Install the bottom row of transistors starting from the transformer, NPN, PNP,NPN, PNP. Remove the one wire to the upper left backplane 6-32 screw byremoving the securing nut and floating this wire in the air. Install railfuses. Check for infinite resistance between chassis groundand the transformer cases. If not debug. (you will get a readingbetween DC ground bus bar and these cases, you meter will be charging up thebulk caps)
Connect a ~10K resistor between the output and ground test point on eachbackplane.
Install rail fuses
Bring up on DBT and Variac to 60VAC in on the AC input. Make sure all isgood and no smoke is coming out. Measure that you have B+ and B- voltagespresent at the respective test points and B- at PAD12 and B+ at PAD 11 on eachback plane board.
Check that you have 0V at the output test point.
Take the Variac all the way up and repeat.
Next, before doing anything else, power the amp down and fully DISCHARGE thebulk caps using a 1K 2W resistor (any value close to 1K will do) down to alevel below 1V.
Then you are good to proceed to the next assembly step if this is all good.
