FOR SALE Phase Linear 700 Series II - 2 New WOPL BUILDS
#24
Well Lee, I got some test time in on the Prism dScope and I printed some of the results out but as soon as I started going through the test results, I have a bit of work to do. The amps are fine it's just some of my graphs are funky... I got my X axis on a couple of tests set up as Frequency where it should be in a unit of amplitude (for Gain vs Amplitude test) where Gain is the Y axis (in dBr) and the X axis is sitting in 10 -20Khz.
I have been taking some generic tests they used on this dScope at the Tron Shows for potential customers and customizing them for the WOPL's. Just gonna take some time.... I really like this tester, it takes like 3 minutes to sweep through the 11 tests I am using. I need to add a couple more like Power out but it will come soon.
You'll see what I mean below. I got freq's on both Axis... I'll get it yet...
#25
It takes the AP at least 3 minutes to do a THD & N sweep. It is settable between 75 and 150 points, and 3 speeds, slow , medium and fast. I use the slow and 150 point test, cause in THD & N testing, slower is better....
#27
Will it also print the numeric tables of the same graph?
Yes, but I don't have Excel on this computer. I have a lot of work to do. I'll start posting the tests one at a Time and let you look at em. It also logs all the settings of the tester so you can help me get all the bugs out.
