Skipshot's PL 400 Ser II WOPLization
Baseline testing on Skip's 400 today.
Man, this is about a clean and quiet 400 as I have EVER seen for a stocker......
Residual Noise, Un-Weighted 10hz to 30khz...........
THD & N , Un-Weighted, 10hz to 80khz...
Phase Lag/Lead, reverse the positive and negative numbers.....
Other measurements....
Frequency Response.....
Listening to Skip's stock 400 right now. From the specs you would think this would sound like a WOPL, but alas it doesn't, bass is flabbier, a lot of sibilance ( well, more than we are used too with the Rev E board)...and I haven't even pulled the tranny covers to see if it's a quasi or full comp....
SOUNDS like a quasi though.....
The Shpongle flutes could elicit some listener fatigue......
Shpongle will show all weaknesses............... I hate a flabby bass... Unless you are talking about the fish.
Standard test tunes are Shpongle, Crystal Method and Moby.....with a little Patricia Barber thrown in....
On Moby---"Play" track 4, there is a LOOOOOOOOOOOng extended bass note that gets DOOOOOOOOOOOOOOOOOOOOOOOOOOOOOwn........
Crystal Method ----"Vegas" Track 4 has the same thing and maybe a bit lower
Shpongle----"Are You Shpongled" Track 6 "Divine Moment of Truth" is some very "crowded" music. A lot going on in that song.....at the same time, excellent test tune..
Patricia Barber.....You can hear her swallow the mic.....
I should be ready to test the 2 Clair's (WOPL's) I'm going to finish in the next 2 days, I'll run them across the dScope and then I may need to purchase some of those recommendations to give them a burn in/ear test.
From the pic I'm guessing it's a quasi.
From the bass alone I'm 99% sure it's a quasi. Don did I ever send you the meter I promised??
PM your address again Don and I'll get it on the way. I have to break up a set anyway, and I got to thinkin I hadn't sent yours yet....
