That all looks good Joe??? Going by the guide sheet I was looking at for test voltages things were way off... I will go and edit the first post and put the voltages from the chart I was looking at... From an excel doc called PL14_20 RevE board voltages - Full Comp
The measurements you got are spot on Ray. The cheat sheet you referred to is for an earlier revD board wired quasi comp.
I will delete it from the docs I send. The plus and minus 78V readings are the nominal for the transformer, vary with line input.
.... looks like I have a wopl 400 lol... the green wire you had me put on the upper right right channel control board I think it is B+ out (don't have in front of me right now) for Don's protection board.... that will go to J3-1 DC input right?
