That all looks good Joe??? Going by the guide sheet I was looking at for test voltages things were way off... I will go and edit the first post and put the voltages from the chart I was looking at... From an excel doc called PL14_20 RevE board voltages - Full Comp
The measurements you got are spot on Ray. The cheat sheet you referred to is for an earlier revD board wired quasi comp.
I will delete it from the docs I send. The plus and minus 78V readings are the nominal for the transformer, vary with line input.
