- Jan 14, 2011
- Gillette, Wyo.
Mains fuses are ten, power switches were rated at 3 amps.....should do fine....
Yer gonna put a 5 cent Chinese switch in a $2000 WOPL?
Yer gonna put a 5 cent Chinese switch in a $2000 WOPL? Go with the American made one's JOE showed. I'd get a hold of a rep and talk to him. There ain't no way I'd put that Chinese shit in one of my amps. Just saying, you get what you pay for and those are some cheap friggin switches.
http://senasys.com/product/2511-series-34″-thermostat-switch-notched-bracket-l
You need to order the ones with the 0.938 spacing, the mini ones.
Those are the 430 series surface mount, NOT the large surface mount.
90 degree lead bend makes the terminal stand straight up which is what you want.
Do you have a link, or maybe you have some? I need to order an LED board for the 700B anyway.
