Another WOPL 700B buld
#42
Billboard
North Shore Massachusetts
Yer gonna put a 5 cent Chinese switch in a $2000 WOPL? Go with the American made one's JOE showed. I'd get a hold of a rep and talk to him. There ain't no way I'd put that Chinese shit in one of my amps. Just saying, you get what you pay for and those are some cheap friggin switches.
http://senasys.com/product/2511-series-34″-thermostat-switch-notched-bracket-l
You are absolutely right, in another thread on this same amp I searched high and low for quality input pots, I ordered some and refused to put them into the amp until I was happy with the quality. I am not one to settle.
I will call Senasys and make sure the mounting space is correct and order a pair. I will report back on my results.
I have over $1.100 into this amp right now and I am not done yet. I am guessing this build (including the purchase of the amp) is going to cost me $1,300.
Billboard
Ok I ordered two Thermostats from SenaSys I ended up with the 430 series, 170 degree cutoff, 45 degree terminal offset (same as factory), rated at 15 amps, and will fit the original mounting holes.
US made and in stock
part number 430-301A284-540
#49
Yes, the straight up terminals are the 90 degree which are the same as the originals. This is what I got from the Rep.
Perry,
If you are requesting 90º terminals, the part number will be 430-301A285-540
Temperature specification: open on rise, open at 170ºF +/- 5ºF, close at 155ºF +/- 5ºF
Thermostat pricing and lead time is quantity based; if the order quantity is different please obtain correct pricing.
Quantity 1 = $9.75 USD each, 3 - 5 day lead time ARO/payment received.
FOB = origin, Altoona, WI 54720 - recommended shipping method is USPS Priority mail ($6.80 USD for small quantity 1 - 5 orders).
Thank you,
Karen Fenimore
SENASYS
704 Bartlett Ave
Altoona, WI 54720 USA
Phone: 715-831-6353 Fax: 419-818-0897
Email: info@senasys.com
don't know if this PDF will work
View attachment 430-301A285.PDF
Billboard
previous post deleted, it was all wrong info.
Lightning fast shipping from Senasys, got the thermostats today, the post above was correct, about the 90 degrees being the angle of the terminals, however the thermostat does not fit the mounting holes, looks like it could be drilled for the correct spacing.
#55
You need to order the ones with the 0.938 spacing, the mini ones.
Those are the 430 series surface mount, NOT the large surface mount.
90 degree lead bend makes the terminal stand straight up which is what you want.
Billboard
Do you have a link, or maybe you have some? I need to order an LED board for the 700B anyway.
Billboard
I will either reuse the old thermostats or find new ones.
OK, this is were I need help, I have the boards built, transformer mounted to the new chassis, now what?
mount the backplane boards then??
AC wiring?
AC socket: Neutral to outlet, then transformer up over the top of the chassis
AC Socket: Hot to fuse, switch, outlet, thermostats (x2), then transformer.
Then DC wiring??
#59
Backplanes in next, then the rest of the wiring. Get the rest of the mechanicals in now, speaker posts, RCA jacks, etc. Thermoswitches after the backplanes are in...
Billboard
Backplanes in, mechanicals installed.
Is there any mechanical fastener to hold down the backplanes (other than the output screws).
I installed the two upper screws and spacers, I know one is used for chassis ground, do they hold down the backplanes? how?
