grapplesaw
Latest update... I got the amp back. Before I went to hook it back up I ran some test on the pre-amp. I should have tested it before but I just wouldn't believe it could be it as I have been using it for about 2-3 years ever since I had had it restored by Carver Audio Repair.
I need to do some research but I have about 250-270mvdc on the left channel whereas the right channel is reads .0002mvdc
So apparently I did a good job building the amp..... WooHoo! Thanks everyone for your help...! Now I'll to start a thread on trying to fix the preamp... although I think it might be over my abilities! And/Or buy a different preamp, though I am partial to my Carver C4000!
There are several threads on these units. I have one and had problems. I found may of the boards can be removed and still have it work. You may want to remove the amp board for the delayed speaker section and see how that effects things. Being a amp section it maybe is back feeding into the low level sections.
Just a thought.
