WOPL 400 Build Problem!
#61
Well, we don't want any outputs in yet. After you remove the outputs, bring it up on the DBT to check for shorts in the power supply.
nadude98
Terre Haute, IN
Well, I had already, brought it up after retesting for shorts with the bottom row of outputs in as per the instructions for bringing it up for the first time. I removed the ground wire and tested from output cases to chassis ground and had infinite resistance. I reconnected the ground wire and put the 10k resistors between output tp and ground tp and brought it up on the DBT and checked the B+ and B- for appropriate voltages. B+ was +84.5 and B- was -84.5, I then installed the rest of the outputs and posted. If you want me to pull them I will, and if so how do you want me to test for shorts in the power supply?
#63
You've already done that. Reinstall the board. Check offset as you bring it up. If you have excessive offset after 60 volts on the rails shut down and remove 6 and 9 wires and try again.
#65
I forgot you did not have one. Not really necessary here, but now that you have it ordered it would be nice to use it...
nadude98
Terre Haute, IN
When you checked the power supply did you check the +/- 15 volt supply?
Something seems strange to me. After I took everything apart and restarted using the DBT it doesn't even light up at all anymore.....? Used to get real bright and then dim out...Not sure what's up with that!
#74
It probably means that your bulk caps are still fully charged. Be careful. Discharge them with a 200-1K resistor.
nadude98
Terre Haute, IN
Dang, I would have thought they would have discharged overnight.. I have a couple of 1k's with clips I've been using.. Thanks!
In the USAF we used to use shorting rods on the big caps.... that was always interesting!
#77
A good way to do welding :)
nadude98
Terre Haute, IN
No it is a integrated circuit which functions as a precision zener reference when in the circuit. It does not test like an NPN transistor.
Ok, well I had an order to get from mouser to recap a Pioneer A60, I added a couple of those to the order and it'll be here tomorrow. Maybe I should replace since there was an issue with +15v side
