See you did know what a bias transistor is Larry. They are 2N3403 transistors in the stock amp, as it is labeled on the P-strap. The P-strap is the aluminum bracket around this transistor that is shaped like a P when you look at the end of it.
On the main forum index page, to the right of the "Latest Topics" box is a small double arrowed box. If that tab is enabled There will be another long box that says " New Forum Posts". That is much handier to see if you or I have posted as opposed to hitting the refresh button. You can bounce between the main forum page and your thread by use of that box too.
<dl class="userinfo_extra"><dt>Join Date</dt><dd>Jan 2011</dd><dt>Location</dt><dd>Gillette, Wyo.</dd><dt>Posts</dt><dd>40,703</dd></dl> Halfbiass...Electron Herder and Backass Woof
RED C / BLACK B
1 O
2 O
RED C / BLACK E
1 O
2 O
RED E / BLACK B
1 O
2 1.653
BLACK C /RED B
1 .903
2 .776
BLACK C / RED E
1 .956
2 .751
BLACK E / RED B
1 .905
2 .777
RED C / BLACK B
1 O
2 O
RED C / BLACK E
1 O
2 O
RED E / BLACK B
1 O
2 1.653
BLACK C /RED B
1 .903
2 .776
BLACK C / RED E
1 .956
2 .751
BLACK E / RED B
1 .905
2 .777
RED C / BLACK B
1 O
2 O
RED C / BLACK E
1 O
2 O
RED E / BLACK B
1 O
2 1.653
BLACK C /RED B
1 .903
2 .776
BLACK C / RED E
1 .956
2 .751
BLACK E / RED B
1 .905
2 .777
If you google a transistor number you can find a data sheet that shows the pinout designations.
Desolder and remove the bias transistor leads from the back of the board and test again beginning wiyth red on base and black on emitter. Then red on base an black on collector.
