drummergrl
- Dec 19, 2014
I can't find any specs to post here for you guys to help answer my question.
Thanks!
So...explain what the numbers mean in a S/N spec sheet listing, pretend I'm really dumb. Where do you want the stated number in db to be for an excellent pre-amp? The lower the number the better, right?
Great phono section, otherwise a piece of shot. The unit contains 14 relays and if they have not been upgraded to the sealed nitrogen units, stay away from em...
The 3300 II, 3600, and 3800 are good units. Signal to noise ratio is the difference, in decibels, between the noise floor and max output.
Used to judge how quiet and we'll built the unit is. Poorly designed and built components do not have good SNR.
What about the 4000t?
http://www.ebay.com/itm/131576383186?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
probably not for me, I have no use for surround sound
P.L.F. and Marcov both have one of these and they have done extensive renovations to them and swear by them. I have not even had the lid up on one...
