- Jan 14, 2011
- Gillette, Wyo.
No load connected, inputs shorted, Pots all the way....
I am going this way to I thinkI've never had a pre-amp go DC on me. Joe has but under severe circumstances. My personal 700's no longer have the options for Normal/Direct coupling. I'm naked on the inputs. The 400's don't suffer from naked inputs , and neither do the 700's....just my 2 cents worth...
ThanksGlen , I think any decent pre-amp is all that's needed...
Hello everyone
its been a while now since my last post so I wanted say I am very happy with the amp as it has preformed flawlessly.
Many things have been going on with me so time has been short to do much building but I am happy to say my upside down biuild is underway and I will show that off soon. I will clear up your question's Upside Down WTF in a new thread.
Over the past few weeks l have rebuild my HP 334a distortion tester only to be disappointed with the results and finally replaced it with a Keithley 2015 thd+n tester so I could see how clean this puppy is.
The Keithly, made in the USA, is a great unit and good enough for my needs. We have .018 thd at 45 volts
Now to the present question "high pass input filter"
You may or maynot know the 700's have a high pass filter while the 400's do not
After a lot of running time the sound of the amp has changed remarkably. Now I have still some noticeable difference in sound when played with the high pass input filter engaged(normal setting) and with it set bypass (direct coupled) mode. I have read a lot on low pass capacitors as an outcome of this.
From mkp caps, which is what is installed, to exodic Teflon , Russian, oil filled, paper rapped, honey coated, etc. all have differences in sound quality and more over price. Maybe all I need is more hours on it but this leads to more discussion
I think the best choice for sound is no low pass filter, but I could very wrong on this so please follow along as this gives no DC protection in this setting.
Well (light goes on) we have Don's DCP board on the output side, so my first question is is that sufficient for speaker side? What about the amp itself after all it was build to be a DC output amp for motor control before ever being concidered to power speakers?
The 400's don't have any high pass filter then can we eliminate it now on the 700's is my question?
if I do remove the cap on the input does the remaining 220k resistor have any good or bad effect or should it go to?
I plan to try issoaltion transformers on the input which also convert the higher + 1v and -1v input XLR voltage to standard 0-+1 line input from my soon to be installed Sunfire preamp.
Amazingly Transformers will not pass DC current so there is the safety high pass filter.
Not so fast I have discovered. As you apply near DC voltage to a transformer close to full line voltage we get satiation of the transformer core resulting in high low end distortion . This could cause big problems so it is recommended to add a high pass cat on the input to the transformer. I should have quite before I started.!!!!!!
So now I have come full circle with the Dam high pass filter not sadly leaving the application.
I think I may proceed without any high pass filter anyway .
So Does anyone have thoughts on this?
By the way Joe you rock! This stuff works !!!!!!!
Ok, get all technical on me...a 48khz square wave ACTS like DC ...kinda....sorta....maybe....
Thanks DennisThat looks sexy Glen. I like that contrast between the black face plate and the stainless back plate.
Perry the knobs mirror off the stainless. I am going to order some black knobs like you use and see how that looks.Very NICE, I like the contrast of the SS.
