PL Model 700 Series II with LEDs that just won't work!
#62
Guys, I'm gonna pop for 20 just because, when i get em I'll resell for just what I have in em....OK??
#65
Poor Greece..I expect them to bail out of the EU......that's the only way they'll survive...
#66
I bought some STV-3 and 4H's from Germany 3 years ago and the rate was brutal then....
#67
Nobody has used them for a long time Lee so any technology development died quite a while ago. Probably the best contender is the LM3915 and that is a lousy chip too. No really good options out there.
All the LED light bars I've been seeing on you-tube use that....well.....the ones that say what they are using say that....mostly.....kinda...
grapplesaw
Vancouver
So I saw a YouTube short with a guy from Finland how had put blue led in his series ll amp
i tried to contact him without luck to see what he used. I found these a while ago and am temped to get some
I would have to cut up the array to fit 36 led holes
Anyone done or got info on this?
here is the ones I found
http://pages.ebay.com/link/?nav=item.view&alt=web&id=171344653390
grapplesaw
Vancouver
Here is the link
The Guy's name was Flip Eykens
https://m.youtube.com/watch?v=X-s7PiXlhjA
Flip said this
Hi,I'm just fooling around with some 10 LED BARGRAPHS which I found on ebay. One of my Phase Linear friends asked me to renovate an older Phase Linear. Because the LED's didn't work like it was when new I searched on the internet for replacement. I didn't find any originals because their bars of 12 LED's (3 bars), so I put 4 of 10 (some aren't) connected (and isolated from the PCB). If you look very good to the movie, the right VU meter has for the last segment (about 100 Watt till clipping) a red bar.If you are handy and know the basics of electronics, it is quit easy to pimp your Phase Linear. It is not a kit - it was just done for fun after the asked me. I think it will look alse very nice with white LED's
#70
I wonder if that's "our" Mark58Comer that asked about them in the comments section?? They do look pretty damn cool.
grapplesaw
Vancouver
grapplesaw
Vancouver
They're still in pdf Glen.....jeez a lotta help I was...
That worked Lee!
I could not get opened in eBay I guess
Next week I will measure them for fit When I get home.
i would build a couple if it looks good to work spec wise.
the array should be able to be cut to make 36 units or we could mix Colors like for clipping. These guys have other colors.
#79
Ok. Been reading up on the 3915?? You can cascade them together to get any amount you want.
bhuskins
That worked Lee!
Those 10 segment should fit because the originals are 10mmX30mm
I may order enough blue to fill the graph and put a segment of 4 red on the end for the clipping
