- Jan 14, 2011
- Gillette, Wyo.
Amen, the worlds best solder made short work of the speaker posts. Got the DC protect off, now have to open the holes in the DC protect board and the chassis...to accept the new speaker posts. The RCA jacks you sent wont work. I have some new factory silver jacks I'm gonna use. The RCA jacks you sent have a smaller shoulder and the shoulder washer is sloppy in the factory hole....
Lee what size are those posts? I have some 30 amp #10 I could use if the board can take opening the holes up to #10 holes. Don did not recommend drilling his 700 boards.Done with that side....On/Off switch and we're done....
Good to know LeeI know he doesn't recommend it But I've done it twice with no I'll affects. I drilled these out to .193
