Let's hijack this thread again
Started to assemble the new rev B backplates tonight. They are realy cool.
so here is a twist
Some may think I am crazy, no names mentioned right Joe, as I will build an upside down unit.
the control board and back plates will be inverted top to bottom. The power will run straight down the bottom from the fuse. I put in a SCHURTER Conn AC 3Pin power plug in my old parts chassis.
Also I moved the fuse to the old power cable hole. I had drill new holes for the temp switches, a few other holes and sloted the outer pairs of pin holes for the transistors in the top and bottom of each row to aline with the pin holes. All done now. This is the chassis which is now left over from my build using Joe's new chassis, don't worry I am not touching that one. To bad Ebay, I guess it will not make to the auction block. It's going to be cool.
So now there will be no Ac near the low voltage control wires., not that there is a problem with the original top run ac with the back plate builds.
