Sold!
For Sale JVC TD-R611 Auto Reverse Cassette Deck. Good working two head Cassette Deck. I made some wood side panels for it. The wood panels are siliconed to the metal top cover with holes drilled to access the hold down screws. It is in good condition with some rack rash on top from other components sitting on top of it. Matches other JVC decks from the same late 1980's time period. Makes a nice playback deck for a secondary system.
JVC TD-R611
Stereo Cassette Recorder (1988)
Dolby B/C noise reduction and HX Pro headroom extension
Description
Equipped with direct input terminals, starts a new style of tape decks.
Quick reverse silent mechanism. SA rec/play head using the most transmission efficient LC-OFC head coil. MPX Filter with on/off switch. Digital peak level meter with peak hold function. Auto tape selection mechanism. Music scan.
Specifications
Type: auto reverse, 2-head, single compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x record/playback, 1 x erase
Motor: 1 x reel, 1 x capstan, 1 x mechanism
Tape Type: type I, Cr02, Metal
Noise Reduction: B, C, HX Pro
Frequency Response: 15Hz to 19kHz (Metal tape)
Signal to Noise Ratio: 58dB
Wow and Flutter: 0.05%
Total Harmonic Distortion: 1.0%
Input: 80mV (line)
Output: 0.3V (line)
Dimensions: 435 x 132 x 336mm
Weight: 6.8kg
Year: 1989
Includes the deck and a printed copy of the owners manual from HiFi Engine.
Asking price $35 plus shipping. Shipping in the USA will generally run $25 to $30 depending upon your location. PM me if interested.
JVC TD-R611
Description
Specifications
Input: 80mV (line)
Output: 0.3V (line)
Weight: 6.8kg
Year: 1989
