Sold -For Sale JVC TD-R611 Auto Reverse Cassette Deck Sold
Web Police
Bloomington, MN
Moderate in Moderation
Sold!
For Sale JVC TD-R611 Auto Reverse Cassette Deck. Good working two head Cassette Deck. I made some wood side panels for it. The wood panels are siliconed to the metal top cover with holes drilled to access the hold down screws. It is in good condition with some rack rash on top from other components sitting on top of it. Matches other JVC decks from the same late 1980's time period. Makes a nice playback deck for a secondary system.
JVC TD-R611
Stereo Cassette Recorder (1988)
Dolby B/C noise reduction and HX Pro headroom extension
Description
Equipped with direct input terminals, starts a new style of tape decks.
Quick reverse silent mechanism. SA rec/play head using the most transmission efficient LC-OFC head coil. MPX Filter with on/off switch. Digital peak level meter with peak hold function. Auto tape selection mechanism. Music scan.
Specifications
Type: auto reverse, 2-head, single compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x record/playback, 1 x erase
Motor: 1 x reel, 1 x capstan, 1 x mechanism
Tape Type: type I, Cr02, Metal
Noise Reduction: B, C, HX Pro
Frequency Response: 15Hz to 19kHz (Metal tape)
Signal to Noise Ratio: 58dB
Wow and Flutter: 0.05%
Total Harmonic Distortion: 1.0%
Input: 80mV (line)
Output: 0.3V (line)
Dimensions: 435 x 132 x 336mm
Weight: 6.8kg
Year: 1989
Includes the deck and a printed copy of the owners manual from HiFi Engine.
Asking price $35 plus shipping. Shipping in the USA will generally run $25 to $30 depending upon your location. PM me if interested.
You have five or so nice shots of the entire front and not one of the eleven is in the reverse mode. Does it record?
Web Police
Bloomington, MN
Yes it reverses, and yes it does record. It is a functional deck. I took all the images at one time and didn't change the direction of play and of course didn't want to record over the tape in the well. I'll have to record a tape and shoot an image of play in the reverse direction when I get a chance.
Check original post for image of deck playing in reverse and image of deck recording. I recorded a tape (both sides) today and it sounds good. I didn't use dolby though as I am not a dolby fan.
It is a 25 year old deck and while it sounds good to me who knows how the components have aged.
I discovered I have one sitting in the shed yesterday while rearranging. Needed belts I reckon.
I think I had another member bring it through the border to reduce postage if that was the one and there was other stuff in there.
If you need to sell it on eBay, please do. In my case I'm trying to get money to Ron ASAP and I am not buying as many cassette decks as I was while I get what I have in order.
Web Police
Bloomington, MN
It is available for sale here. Not sure if it will be going to ebay or getting donated if it doesn't sell here.
Australia
I'd buy it if I was closer and not financially screwed. Quite a desirable deck being a 'quality' auto reverse unit.
Web Police
Bloomington, MN
There doesn't seem to be much love for auto reverse decks out there. I like them for playback though.
And yeah unfortunately shipping anywhere out of the US doesn't work for inexpensive heavy gear. I acutally have a another deck just like this without the wood panels too. I may have to try and sell them locally so shipping isn't a factor.
Australia
The main issue is the rotating head hitting the azimuth adjustment screws and going out of alignment over time. The dual well auto reverse decks are the worst. But I can see that JVC unit producing quality sound as long as azimuth is corrected when it moves slightly over time.
BlazeES
Teac 4-track heads are awesome for auto reverse, albeit far from perfect. No rotation.
Web Police
Bloomington, MN
Yeah most of the time I use the two head as playback only decks in areas where perfection doesn't matter. In my garage or for background listening.
Australia
I have a 4 track auto reverse head in my alpine car deck, it is the most precise auto reverse unit I have ever heard. It never goes out of alignment and both directions have equal superior fidelity. If it wasn't in my car I'd use it as a home deck as it plays worn tapes with minimal drop outs. I think it might be something to do with the SCC2 Head, as the head has two spots which are sunk down which the tape barely touches. I have a picture of a pioneer car head deck which is of a similar style:
BlazeES
I owned an Alpine under-dash unit long, long ago. It was a sweet deck. FM only but at the time I couldn't care less.
It did an excellent job of tape playback of home-brewed tapes. Awesome engineering baked into that one.
I periodically try Googling that beast but always come up empty.
It was a unique rig.
I miss that deck ...
