Ferro Extra I is no muss, no fuss for me and I love it. Suggest you find some manuals for those decks if you haven't already and make sure you aren't set for Type II by accident.
Its an auto tape selector deck, it selected Type I correctly, its just that it can't adjust the bias far enough for a flat response to come from that tape. My JVC has also had issues adjusting to some BASF tapes as it just doesn't have enough range in the dial. My Yamaha KX-530 also had much lower treble response with BASF type 1 and 2 tapes. Any other mainstream brand (TDK/Maxell/Fuji) has had no issues in those decks. I know that the BASF Chrome Maxima that I tried in the JVC required the bias to be turned to the far left, there was just enough range for it to produce a flat response. BASF tapes are more difficult to bias in all the decks I have tried. If they do bias correctly, they sound fine, but if not its just not worth making a recording on them.
