Too loose and they wont transfer heat well. They MUST be more than finger tight.
THAT is a VERY good sign. If that holds true on the first set of 15024's we're halfway home...
OK, power down long enough to blee the PS caps. If in doubt, measur DC volts left in caps, Pos lead on B+ cap terminal and Neg lead on B- cap terminal. Wait till they are below 4 volts, THEN AND ONLY THEN, hook up leads for bias adjustment.
For bias adjustment, pos lead on the base bus bar, neg lead on the emitter common tie point. Volts in DC millivolts.
I am thinking I need the clip type leads for this since I am working in a live circuit.
Is there an "explain like I am 5" bias adjustment guide? I am reading the manual and just want to hear all of it in different words to make sure I do not mis-step.
You want something like these for this job:
search for minigrabber test leads. Many places sell them.
I just bought a pair of mini alligator clip leads from radio shack, who wanted to charge me double the price for them that their own website listed...
Anyway, now I am setting up to test this bias and the caps etc.
